Page 2 of 2
I suppose technically this counts
Posted: November 24th, 2015, 1:00 pm
Marcle leisure came across this gem on a trade page on FB
here it is on our own page
https://www.facebook.com/photo.php?fbid ... =3&theater
Re: Demountables spotted
Posted: November 24th, 2015, 1:39 pm
whats happened there please?
Posted: November 24th, 2015, 1:42 pm
by TrueDink
Looks like another Navara has fallen victim to slight chassis re-alignment.
Re: I suppose technically this counts
Posted: November 24th, 2015, 3:54 pm
by hondababe55
zildjian wrote:Marcle leisure came across this gem on a trade page on FB
The stance of this - camper pointing skyward, is very much like the one I saw on the A34 nr Bicester a few months ago.
Posted: November 24th, 2015, 4:14 pm
You did mention that didn't you, not the same one is it?
Posted: November 24th, 2015, 6:28 pm
by hondababe55
zildjian wrote:You did mention that didn't you, not the same one is it?
It could be Zildjian as this was about the same as the one I saw. Scary isn't it?
Posted: November 24th, 2015, 7:20 pm
Jury's out on this one,
snapped chassis rail(s)
bent chassis at very back
front tie downs missing/broken/not fitted (so camper lifted by wind)
none of the above are ideal really
so what about this avatar then Viv?
Posted: November 24th, 2015, 9:42 pm
Actually if you look at that reflected white line down the side, you can see its not the same on both cab/Tub in fact it looks as though its tilted back a good bit after all
what do you think gang?
Posted: November 24th, 2015, 9:48 pm
Definitely something wrong, but that load bed doesn't look right looking at the reflection as mentioned
Posted: November 24th, 2015, 9:54 pm
by sabconsulting
I imagine it is chassis as per usual. If the load bed was pulling away from the chassis I would expect it to have failed catastrophically already - i.e. if the mountings started to fatigue they would have failed completely before achieving this level of deflection.
Either that he is starting to deploy the camper into launch position
