oh no its happened again!!
Re: oh no its happened again!!
Post: # 4021Post zildjian
February 10th, 2015, 9:11 pm
My cargo straps just hooked right in there actually, passed up between cab/tub and onto camper
martinjdover
Post: # 4044Post martinjdover
February 10th, 2015, 10:33 pm
The Defender doors rust partly due to the shape of the steel section which traps dirt and that blocks up the drainage holes. The dirt therefore remains damp and this exacerbates the problem. The chassis on the Defender is a massive box section - actually two C sections welded together with a lap joint. Mine gets a lot of abuse and I have had to weld on one small patch but he rest of it looks really solid.
I've put on two new front doors and I bought two 5 gallon tins waxoil to give all the steel bits a good going over a few years ago whist the steel was in decent order. Unfortunately this is one of the tasks I haven't got around to and the tins have yet to be opened!
Post: # 4048Post zildjian
February 10th, 2015, 10:41 pm
Easy to work on though Martin, you just need a 13mm spanner & flat blade to open the tin with :D
Post: # 4049Post derestrictor
February 10th, 2015, 10:43 pm
does it work retrospectively, Ia lways heard it needed spplying with car completely new and dry showroom condition really
Post: # 4312Post Mike
February 21st, 2015, 5:20 pm
[/url[URL=http://s1054.photobucket.com/ ... .jpg[/img]
Near side finished by body shop showing the ring bolt for fixing
That side all finished
Drivers side had to be welded as the fuel tank stops access to the other side of the chassis rail
Drivers side all done, pleased with the results looks a lot smarter now.
Post: # 4315Post rubberrat
February 21st, 2015, 7:29 pm
That looks smart Mike... Good as new!
Post: # 4319Post derestrictor
February 21st, 2015, 7:54 pm
What are the red/blue wires there ?
(to do with demountable)?
Post: # 4321Post zildjian
February 21st, 2015, 7:58 pm
fuel sender?
Post: # 4322Post Mike
February 21st, 2015, 8:06 pm
No thats the air lines to the bags, now all coated in glup! !
Post: # 4442Post Mike
February 28th, 2015, 5:35 pm
New tow hook taken from a scrap navara now on near side so I can fasten rear straps to this rather than the tow bar. Both sides now have hooks. They are at a better angle I feel.
