Page 2 of 4
Re: 13 pin electric hook up
Posted: June 4th, 2015, 11:37 am
by Lost in the wilds
Pins are numbered I've just discovered - must be my eyes! On the connector side on the casing - needed a magnifying glass.
And yes, the diagram shows the pins not the connectors.
Still not sure if the plug on the Tischer is wired correctly but working on it.
Chris
Posted: June 4th, 2015, 9:09 pm
by claudius
Good evening Chris,
Here are the wiring of my male plug (in parentheses : section) Tischer 260S
1- brown ( small)
2- yellow with a white line (small)
3- white with a blue line (big)
4- blue with a white line (big)
5- grey with a red line (small)
6- blue (middle)
7- white with a green line (middle)
8- bleu (small)
9- yellow (small)
10- black (small)
11- red (small)
12- white (middle)
13- green (small)
I can see the wire colors are not the same as the standard! Saturday, i'm going to match every pin with fonction!
Pity you do not live next to my house, I could troubleshoot quickly (I'm technician automation and electromechanical)
Hope, i help you
Have a good night
Claude
Posted: June 4th, 2015, 10:37 pm
Claude, you are a star. Many thanks. I'll get on that tomorrow and let you know the outcome.
Chris
Posted: June 12th, 2015, 4:57 pm
We now have all our electrics working!
I contacted Tischer who sent me a pin/wire colour scheme that was wrong - and then they sent me another one which was nearly right..... but didn't work!
I then discovered (as had been suggested) that the Amarok 13 pin outlet was only wired for road lights.
My local, friendly auto-electrician sorted out which cable went to which pin, got the lights working and rigged another cable to charge the battery and run the fridge. Electrickery!!!
Next - rear-view camera - what could possibly go wrong?
Chrs
Posted: June 12th, 2015, 4:59 pm
by keeflester
Perseverance won out in the end. Good luck with the camera.
Posted: June 12th, 2015, 5:22 pm
The camera I can help you with when you're ready
Posted: June 12th, 2015, 6:42 pm
by Bookend
Well done getting it sorted.
Rear view camera sounds a good idea (wireless I presume). Don't know where I would fit the screen though.
Posted: June 12th, 2015, 7:28 pm
Posted: June 12th, 2015, 7:36 pm
by Bookend
How does the visor handle the extra weight? Mine are a bit floppy already.
Posted: June 12th, 2015, 8:11 pm
Oh I'm sorry mate you'll have to ask over on
Personal gentleman's problems on that one
as far as the sunvisor goes, mine didn't need it but I think it can be tightened can't it I'll look tomorrow and report back
I would say however if you wanted to view it while driving forwards (in traffic say) it would have been better mounted an inch or so lower down the visor towards the bottom
but thats all
