Post: # 17706Post
May 5th, 2017, 9:23 am
For those of us who have to move the loo around in the camper it is quite awkward and heavy . I have made this gadget to make it easier , same principal as a wheel barrow and added 65 mm to the height , which is good.
Post: # 17829Post
May 18th, 2017, 6:59 am
We have had 3 days away around Cotswolds and forest of Dean . It has had a good rain test and all good . The bed length works really well , but I have made a mistake with the width at 4' . Next mod is to steal some space off the seating area to make it wider .
Post: # 17878Post
May 22nd, 2017, 7:53 pm
Bigger bed sorted. Withe the slide out it is 6'8" long by 4'9" wide.
Post: # 18185Post
June 16th, 2017, 8:28 pm
I have fitted a new foot operated switch for the sink tap, it is that black box in the centre . I did have a push to make switch near the sink but very difficult to get water and was your hands.
It just arrived in time from China , off to France on Monday .
Post: # 18359Post
July 1st, 2017, 4:24 pm
I think I have found a contender for an uglier homemade conversion ?
Post: # 18427Post
July 8th, 2017, 10:33 am
How has this camper worked out for you now you are using it, the slide out for extra sleeping room looks a good idea
Post: # 18430Post
July 8th, 2017, 12:17 pm
Although I say it my self it is a brilliant design . For such a small camper I have a massive bed 4'8" x 6'8". I was worried that I might bang my ankles on the opening but I don't even notice the narrower foot end and the box is wider than the opening . It takes about 30 seconds to fit and doesn't stick out too much further than the door mirrors so no body should walk into it . I am 6'4" and Jane is 5'10" .
Post: # 18653Post
July 26th, 2017, 5:33 pm
More storage inside .
I bought 24 caravan doors and a draw unit and I am making the fit the old cupboards and making new ones . The new unit just lift out and the cushions put back in so it can be made back into 4 berth easily .
Lake District on Friday if the weather picks up .
Post: # 19836Post
November 3rd, 2017, 6:37 pm
I have sorted out the rear legs . I have removed the home made jacking system . With out the legs is weighed 19kg , despite the amount of steel in it it was quite rickety where the legs locate.
I have modifed the legs fitted a new Thurle step and a waste water tank underneath. .
I havery also added a brace to the front legs as the camper was trying to lean forward on the legs . It now feels very solid .
Post: # 19841Post
November 3rd, 2017, 8:29 pm
Hi Jim,
I like the position of the rear jacks. I must admit, I hadn't thought of them so close together other than 1 single in the middle.
Also missed the previous picture post, but have noted the slide out worktop. That goes in the book.
Good job
Mark
