A small dehumidifier sounds like a good plan.
I have also thought about fitting a small panel heater when on site with hook up as it seems daft burning gas.
I actually find that heating the air in the camper does make a huge difference. Your breath expels the same amount of moisture whatever the air temperature is, but if it is 8 degrees in your camper the air won't support much of that moisture and it will be forced to condense out onto something. If the air is 21 degrees then it can carry a lot more moisture before reaching saturation point and condensing out.Gary W wrote:...A heater on it's own (without a lot of ventilation) will just make things worse and using your gas hob or any unflued gas heater is absolutely the worst thing you can do.
If it works on our camper, which is as thermally efficient as a baked bean tin then it should work fairly well on yours.Bookend wrote:I did look at one of those but wondered how effective it would be.
