HappiJac 4150
Posted: May 1st, 2016, 4:16 pm
by Pauls130
Re: HappiJac 4150
Posted: May 1st, 2016, 4:20 pm
Hi paul, I've shared this on our
Facebook community
as well for best coverage
Re: HappiJac 4150
Posted: May 1st, 2016, 5:20 pm
by Big Jim
One of mine failed . They have a large nylon "nut" at the top . I dismantled it and investigated repairs . Happijack would not supply me and remaking wasn't cost effective. I bought a new one from Niche Northstar dealer 01507 327172 . I think £270.
I prefer not to use the motors too much , it is too easy to go too far . Doing by hand you can feel when they are struggling .
Message Paul....
Posted: May 1st, 2016, 6:00 pm
"To be more specific the head of the screw tread in the jack has sheared. Looks like the mounting plate inside the jack is bar tack welded on assembly so repair doesn't seem possible"
Re: HappiJac 4150
Posted: May 1st, 2016, 6:39 pm
by Big Jim
You can get it apart by relieving the staking at the top of the leg . It will come apart , but it is a fight , but I don't know how that will help you unless you think it would weld back on. Be careful , there is a square plate around the threaded bar at some pint which is supposed to jam the leg if it fails .I can't remember where it goes and its easy to not see .
message Paul...
Posted: May 2nd, 2016, 1:46 pm
"so some further dismantling this morning. The top pin is a separate part"
Re: HappiJac 4150
Posted: June 6th, 2016, 4:35 pm
by digger.walker
Paul, you might find Niche Marketing ( if they still call themselves that) might be of assistance. I had an overextended Jack and the engineer was able to relocate the thread after a while.
Re: HappiJac 4150
Posted: August 4th, 2016, 9:50 pm
by Pauls130
I forgot to update on this but a local engineering company sorted me out. I rebuilt the jack and it works perfectly.
Hébergeur d'images
Re: HappiJac 4150
Posted: November 16th, 2016, 9:21 pm
Paul can you tell me what the upshot was on this leg in the end?
