TrueDink
Post: # 10123Post
TrueDink
November 24th, 2015, 1:42 pm
Looks like another Navara has fallen victim to slight chassis re-alignment.
hondababe55
Post: # 10130Post
hondababe55
November 24th, 2015, 3:54 pm
The stance of this - camper pointing skyward, is very much like the one I saw on the A34 nr Bicester a few months ago.
hondababe55
Post: # 10137Post
hondababe55
November 24th, 2015, 6:28 pm
zildjian wrote:You did mention that didn't you, not the same one is it?
It could be Zildjian as this was about the same as the one I saw. Scary isn't it?
- Site Admin
Post: # 10138Post
November 24th, 2015, 7:20 pm
Jury's out on this one,
snapped chassis rail(s)
bent chassis at very back
front tie downs missing/broken/not fitted (so camper lifted by wind)
none of the above are ideal really
so what about this avatar then Viv?
- Site Admin
Post: # 10144Post
November 24th, 2015, 9:42 pm
Actually if you look at that reflected white line down the side, you can see its not the same on both cab/Tub in fact it looks as though its tilted back a good bit after all
what do you think gang?
Post: # 10145Post
November 24th, 2015, 9:48 pm
Definitely something wrong, but that load bed doesn't look right looking at the reflection as mentioned
Post: # 10147Post
November 24th, 2015, 9:54 pm
I imagine it is chassis as per usual. If the load bed was pulling away from the chassis I would expect it to have failed catastrophically already - i.e. if the mountings started to fatigue they would have failed completely before achieving this level of deflection.
Either that he is starting to deploy the camper into launch position
