Air bag valves
Big Jim
Air bag valves
Post: # 11186Post Big Jim
January 21st, 2016, 5:34 pm
Where have you put yours ? Has anyone put them in the cab , on the dash or centre console ? It would be easy to inflate when it's cold and raining from a cigarette power point .
Re: Air bag valves
Post: # 11208Post sabconsulting
January 21st, 2016, 9:39 pm
Mine are mounted on a bracket below the back of the truck.
A friend piped his through to the cab of his truck, plumbed into a compressor with valves and pressure gauge so he could adjust the pressure with the press of a button from the driver's seat.
Re: Air bag valves
Post: # 11210Post derestrictor
January 21st, 2016, 9:48 pm
Nobody says you cant' run the air lines into the cab do they, it makes sense to have them inboard out of the dirt anyway,
and as you say, the access to handy 12V outlet for the compressor
Re: Air bag valves
Post: # 11211Post derestrictor
January 21st, 2016, 9:50 pm
or as Zildjian did, add a complete kit with remote :lol:
Bookend
Re: Air bag valves
Post: # 11212Post Bookend
January 21st, 2016, 9:51 pm
Mine are in the centre cubby box but I also fitted a onboard compressor so can control both inflate and deflate from the drivers seat.
There is no reason why a manual setup with a plug in compressor or garage air line couldn't be the same.
It's better in the cab if it's raining saves getting wet ;)
Alexd
Contact:
Re: Air bag valves
Post: # 11219Post Alexd
January 22nd, 2016, 9:25 am
recently helped fit a reversing camera to a Mitsubishi pickup and owner had the small wire come from back of vehicle forwards then up into cabin via and handy rubber bung below drivers seat ( we made a hole in the rubber itself and passed wires through) i think its a sort of water damage drainage hole but not sure, handy anyway
Re: Air bag valves
Post: # 11223Post Mike
January 22nd, 2016, 9:40 am
I just received my new kit this week from Marcelle leisure one of our sponsors here. I was wondering if I might fit the valves and guage block in the engine bay there is a handy empty area just behind the nearside front lights which would house a compressor as well I think, just worried about heat and it might get mucky up there, if anyone has any thoughts all welcolme.
Re: Air bag valves
Post: # 11225Post zildjian
January 22nd, 2016, 12:03 pm
For ease of use the gauges really should be somewhere in the cabin ideally, compressor anywhere out of sight, so under the bonnet (on rubber washers/grommets) is ideal I'd say and keeps the fused power supply handy too
Toshbins
Re: Air bag valves
Post: # 11226Post Toshbins
January 22nd, 2016, 1:10 pm
Ive got a kit on order. Is it a good idea to have it somewhere so that you can see what is happening as you pump it up?
Did I hear that some people use it while unloading the camper - I.e. pump it up high, lower the jacks, deflate and at least reduce the amount of jacking needed on the legs?
saDgit
Re: Air bag valves
Post: # 11228Post saDgit
January 22nd, 2016, 2:24 pm
Toshbins wrote:Did I hear that some people use it while unloading the camper - I.e. pump it up high, lower the jacks, deflate and at least reduce the amount of jacking needed on the legs?
Yeah, and vice versa. On our SKarosser/Ranger combination the camper legs would need to be at, or very near, their maximum extension in order to load the camper. And that high up the camper always feels very vulnerable. Deflating the Air-rides as far as possible (around 10psi) would drop the pickup bed sufficiently to make loading significantly easier and quicker.
