reversing camera install
Re: reversing camera install
Bet your neighbours love you when you return late at night
They do now the 911 has gone
Met a useful man who suggested that you run the 2 wireless senders/receivers as close together as possible so run it to the front wall of the camper and back wall of the cab.
Going to mount camera over door and like you say take power from lights
But better do the solar and snorkel 1st otherwise I'll be buried in boxes
Personally I never had an issue with range TBH I suppose you could shorten the distance still,
which is first snorkel/solar
I was looking at the flexible panels and they do indeed seem a much better bet, how were you going to secure them to roof out of interest?
Sikaflex I think or a heavy duty double sided tape, maye the later as it may be easier to remove if repairs needed, sika is really a one time glue
I will sika the cable box down though
Solar first, still getting up the courage to drill a 100mm hole in the wing
OK I give in, its a good idea and I've copied it on mine, works greatrichc wrote:Hi Steve
So just to clarify you switch on the pickup lights to get the rearview camera working
Cheers
rich
can you tell us how much one of these kits cost, and can they be installed by a novice,
we would like something like this as moving about on sites with people and children about is always a worry
