Is it hassle
Bookend
Is it hassle
Post: # 3187Post Bookend
January 11th, 2015, 7:40 pm
To keep removing and re installing the hard top?
My Hilux isn't currently my daily drive but if we get a demountable it will be as my Landcruiser would have to go to fund the purchase.
As I would use the Hilux for work I would have to put the hard top back on every time.
I haven't had the Hilux long and have never had the top off so am wondering how much hastle it would be.
Re: Is it hastle
Post: # 3189Post zildjian
January 11th, 2015, 7:57 pm
OK to be frank it might, most of us remove canopy in March and replace in September, I don't know which you have some are heavier than others, its not a single person job and takes (ME) 10 minutes to unbolt/unplug and handle,
you're right on the tailgate though(with an apollo anyway) it can stay in place and handily extend the loadbed too!
maybe try it and see whether you'd live with it or not first if you think it might be an issue
Bookend
Re: Is it hastle
Post: # 3195Post Bookend
January 11th, 2015, 9:19 pm
Will give it ago next weekend I think I'll make a frame our of uni strut to slide it onto.
Re: Is it hastle
Post: # 3200Post Mike
January 11th, 2015, 10:00 pm
I have just invested in a block and tackle from machine mart for just under £60, just need to rig up a bar or beam in the workshop so I can raise it slightly from the back of the truck. Then drop it on to my new trolley I bought from Mark (rubberrat) recently.
Re: Is it hastle
Post: # 3201Post zildjian
January 11th, 2015, 10:10 pm
Good idea the hoist if you have room
If your sliding it about and its a fibreglass like mine take care, it has some foam rubber on its underside
(where it sits on truck sides) so don't rip it off
mine has 12 bolts down through 6 clamps (3 each side)
then a heated screen/interior lamp & brake LED cable between cab/tub on N/s multi-pin plug
Bookend
Re: Is it hastle
Post: # 3202Post Bookend
January 11th, 2015, 10:13 pm
It's a steal top so the weight is a concern.
The wireing isn't currently connected so will just lift off.
TrueDink
Re: Is it hastle
Post: # 3203Post TrueDink
January 11th, 2015, 10:37 pm
I too use a block and tackle and a couple of ratchet straps. I take my canopy off and on every time I mount my camper and lower it onto my flatbed trailer. It only adds about 10mins to the mounting process.
Re: Is it hastle
Post: # 3208Post zildjian
January 12th, 2015, 3:40 pm
So in steel then that would be like an ifor williams top I suppose,
at least they would be lighter than the fibreglass wouldn't it?
Bookend
Re: Is it hastle
Post: # 3216Post Bookend
January 12th, 2015, 7:53 pm
Its a SMM as fitted by Toyota
Re: Is it hastle
Post: # 3219Post zildjian
January 12th, 2015, 8:13 pm
Oh I don't know those, looks very smart though,
how is it fixed ?
