How have you 'improved' your camper
Re: How have you 'improved' your camper
Post: # 8867Post zildjian
September 27th, 2015, 1:18 pm
Fitted a more efficient TV as suggested by Martin.
(Re-fitted & remade) spice rack thing as it wasn't up to Keith's level of expectation
and all together I think the colour pulls the whole scheme together /S
lamp-it
Post: # 8873Post lamp-it
September 27th, 2015, 2:34 pm
net curtain wasnt there last time either :cry:
Rob
keeflester
Post: # 8881Post keeflester
September 27th, 2015, 5:45 pm
Gorgeous Zildjian. That fully meets with my approval. I would even park next to you again.
Post: # 9026Post sabconsulting
October 1st, 2015, 8:13 pm
I did some write-ups of some of the modifications I made on my camper on the US RV.net site. Here are some links...
The roof went all soft and nasty, so I replaced that:
http://www.rv.net/forum/index.cfm/fusea ... 422355.cfm
Then added solar power to the new roof:
http://tinyurl.com/ShadowCruiserSolar
Then replaced the fairly useless 12v converter and cheapo battery charger that came with the camper with a home-made electrical panel and decent battery charger:
http://www.rv.net/forum/index.cfm/fusea ... 467159.cfm
A few smaller projects:
The Ranger has plenty of torque and is therefore high-geared for economy. But that is not great for hill starts on 1:4 inclines, or just manoeuvring slowly. I therefore modified the 4x4 system to allow me to use low ratio in rear wheel drive to save the clutch in these scenarios:
http://tinyurl.com/lowratio4x2
I added airbags before travelling to Morocco. However, the truck didn't really need them and they have made the ride less comfortable :roll:
http://tinyurl.com/rangerairbags
I initially tied the camper down using ratchet straps, but this wasn't very successful, so I evolved a chassis-mounted tie-down system over a period of time - follow the 4 pages below to see the stages:
http://www.rv.net/forum/index.cfm/fusea ... 101547.cfm
The original absorption (3-way) fridge died, so I replaced it with a compressor fridge - though this wasn't without incident:
http://www.rv.net/forum/index.cfm/fusea ... 023145.cfm
Various other bits and pieces - mainly junk I re-used because I am too tight to buy new stuff:
http://www.rv.net/forum/index.cfm/fusea ... 061437.cfm
http://www.rv.net/forum/index.cfm/fusea ... 818427.cfm
New curtains:
http://www.rv.net/forum/index.cfm/fusea ... 719759.cfm
Runners to make the camper fit more tightly in the load bed - to avoid it moving around:
http://www.rv.net/forum/index.cfm/fusea ... 634138.cfm
Post: # 9027Post zildjian
October 1st, 2015, 8:27 pm
The roof and the tie downs (my fave) I've read of course,
given the amount of work carried out in this 'my father's axe' of a camper would you say you are representative of a camper owner of this construction,
as in what is the typical life cycle of a camper
Bookend
Post: # 9028Post Bookend
October 1st, 2015, 8:33 pm
The runners look great I had been thinking of something simular but I was thinking of fixing them to the truck not the camper.
Now I have seen your pictures it looks the obvious solution. Don't know why I didn't think about that solution :oops:
Post: # 9029Post zildjian
October 1st, 2015, 8:39 pm
I saw these over there originally and thought I'd copy them, they are easily made up after all, but I couldn't decide how to fix them to mine without drilling holes in camper, I thought about a shallow tray with these as sides the camper would essentially sit in, then in the truck
Bookend
Post: # 9030Post Bookend
October 1st, 2015, 8:47 pm
Tiger seal I think for me.
No drilling and won't come off
Post: # 9036Post zildjian
October 1st, 2015, 9:06 pm
hows that used, I'm guessing a really grippy mastic product
lamp-it
Post: # 9038Post lamp-it
October 1st, 2015, 9:12 pm
If you knew where the studs were down on that bottom edge you could just fix into them I imagine, and properly sealed up that would be OK surely
Rob
