S.Karosser Wiring
- Madmountainman
S.Karosser Wiring
I'm looking to replace the central vent in my camper - the one above the kitchen/fridge - with a midi heki. The question is, where does the wiring run from/to for the central overhead light? I will need to make the hole bigger to fit the heki and don't want to inadvertantly cut through the wiring.
Re: S.Karosser Wiring
A; Don't know
B; That light is pretty pointless does it matter
I Would guess its fed from (Fridge) side as thats where all the other wiring emanates
TBH if you do damage the wiring it's not such a bother to put right.
- Madmountainman
Very true, but would rather avoid it if possible.rubberrat wrote:TBH if you do damage the wiring it's not such a bother to put right.
