Fitting Three Way Fridge
Post: # 1241Post TrueDink
September 30th, 2014, 7:48 am
A few photos of the work so far.
Frame in
Bottom vent hole cut
Top vent hole
Insulation in
Cover on
Interior framework for air flow
More to follow
Re: Fitting Three Way Fridge
Post: # 1244Post Peaky
September 30th, 2014, 1:11 pm
Just a thought on the insulation side. Rather than use quilt insulation, why don't you use "Cellotex" foil faced foam insulation. 50mm of Cellotex is equal to 100mm of quilt. It'll keep you a lot warmer in the cooler months & hopefully a bit cooler during the summer ;)
http://www.wickes.co.uk/Celotex-50mm-Hi ... m/p/190544
Post: # 1245Post zildjian
September 30th, 2014, 1:13 pm
My mate has just used something like that on his van actually
Post: # 1246Post Peaky
September 30th, 2014, 1:15 pm
We use it for insulating vaulted ceilings on some of the extension's I do the joinery for. It makes a super warm room with only half the thickness of space required.
Post: # 1247Post TrueDink
September 30th, 2014, 2:15 pm
As you can see from the colour of it I had it lying around. It wasn't really necessary but Dometic suggest keeping the fridge isolated from the living space for efficiency and in case of leaks. I just thought I would stick it in seen as I needed to build up the sides of the cabinet to fit the smaller dimensions of the three way fridge.
Incidentally I have a Waeko Coolmatic two way fridge for sale if anyone wants it.
http://s1372.photobucket.com/user/Grant ... o%20Fridge
Post: # 1267Post TrueDink
October 2nd, 2014, 2:40 pm
Bottom vent in
Top vent in
Internal frame for air flow
Started on the top heat shield
richc
Post: # 1379Post richc
October 7th, 2014, 9:22 am
TrueDink wrote:As you can see from the colour of it I had it lying around. It wasn't really necessary but Dometic suggest keeping the fridge isolated from the living space for efficiency and in case of leaks. I just thought I would stick it in seen as I needed to build up the sides of the cabinet to fit the smaller dimensions of the three way fridge.
As I expected, your fridge is too big for the space I have
You won't have a problem selling it, my hand was snapped off for the cr50 i sold
I can bung details on wildcamping for you if you're not a member
richc
Post: # 1753Post richc
October 28th, 2014, 5:58 pm
Just sold a waeco cr50 on ebay for silly big money so bung on on there, for once i didn't begrudge ebays commision
Post: # 1761Post TrueDink
October 28th, 2014, 9:15 pm
Cheers Rich. I've got a load to sell so I'm going to stick it all on together.
