Big Jim
Post: # 12187Post
Big Jim
March 25th, 2016, 2:39 pm
Looking at mine they have seen better days . They also look quite long , they protrude about 45 mm further forward than anything .They also have put dents in the truck bulkhead . Mine is a ribbed design . I was thinking of removing them and replacing them with a full width piece of timber about 20 mm thick. This would get the camper forward 25 mm and spread the load against the bulk head . What does yours look like ?
Thanks Jim
- Site Admin
Post: # 12188Post
March 25th, 2016, 6:26 pm
these
from most car factors or truck factors have two fitting holes either for screws or bolts
Big Jim
Post: # 12190Post
Big Jim
March 25th, 2016, 7:42 pm
That is a much better design than mine .
Big Jim
Post: # 12231Post
Big Jim
March 28th, 2016, 11:35 am
http://www.ebay.co.uk/itm/2-x-Rubber-Bu ... Swxp9W4EBg
I have ordered these . They are 8" long so they should rest on 2 vertical raised ribs on the truck bulkhead , any shorter and it would only catch one . I still think 2" thick is a bit much and may trim them to about 1" . It would be interesting to know how much more payload it would give me by moving the camper forward 1" .
Post: # 12274Post
March 31st, 2016, 8:13 am
can you get behind these to bolt them on, or have you screwed them on with extras long screws?
Big Jim
Post: # 12275Post
Big Jim
March 31st, 2016, 8:27 am
The old ones were screwed on, I think that will be good enough . I don't think there is much point in ratcheting them really hard up again the bulk head as it has little strength . I did try loading the camper about 1" from the bulkhead , but it made it very difficult to drop the camper level , I have a built I ladder rack which gets in the way .I will leave the buffers at 2"
