New Pickup news
Re: New Pickup news
Post: # 9620Post sabconsulting
October 27th, 2015, 10:01 pm
Madmountainman wrote:
Alexd wrote:Can anyone tell me if there is a known issue with Ford chassis's after reading a bit concerning the Nissan Navara ive been searching for similar on Ranger but not seen much mentioned thanks in advance
Alex
Not to my knowledge, though the Ranger does have issues with the clutch dual mass flywheel, but then, so do most modern vehicles with these.
On the subject of carrying capacity of the new Navarra, I believe it's only 940kg on a double cab.
My '07 Rangber's dual mass flywheel needed changing at around 90,000 miles :roll: I suspect I was putting it through a fair bit of load towing / reversing the horse trailer and steep hill starts with the camper on. For the last 20,000 miles I've had the ability to use low ratio in rear wheel drive on the road, so that will have reduced the shock load on the clutch a lot. Hopefully the replacement will last.
No problems with the chassis so far, but being supercab means more camper is in front of the rear axle which helps the chassis.
FinAde
Re: New Pickup news
Post: # 12982Post FinAde
May 3rd, 2016, 12:35 pm
Fans of six cylinder diesel engines, this is for you. :D
http://www.commercialfleet.org/news/lat ... arok-range
Tischer 230
VW Amarok
Madmountainman
Re: New Pickup news
Post: # 13026Post Madmountainman
May 5th, 2016, 8:39 pm
Well, it's about time too. However, it'll just about render every 2.0L Amarok obsolete and... what kind of software wizardry have they cooked up to make it Euro 6 on the motor industry's emissions lie-ometer. :D
Re: New Pickup news
Post: # 13029Post zildjian
May 5th, 2016, 9:16 pm
Well its going to be nearer the front of everyones mind now, and its not as though it was the first time VW have been caught out
no compensation for European/UK owners either now
