The rear leaf suspension has been replaced by coils springs and (5) multi-link suspension.
I can't recall the exact weight limit on the rear axle. I think the payload was around 1070kg..ish. That's if my memory is working correctlyMadmountainman wrote:
And pray tell, what is the max load on the coil suspension?
Not to my knowledge, though the Ranger does have issues with the clutch dual mass flywheel, but then, so do most modern vehicles with these.Alexd wrote:Can anyone tell me if there is a known issue with Ford chassis's after reading a bit concerning the Nissan Navara ive been searching for similar on Ranger but not seen much mentioned thanks in advance
Alex
